So I received a Bldg Dept comment requesting short circuit calculations for a roadway lighting project. This is the first time I've been asked for this in over 20 years of roadway lighting designing. The power company provided the following information:
Max Available Fault Current at the transformer secondary terminals is 53205 symmetrical amperes at 120/240 volts.
The protective device on the line side of the transformer is a 25-amp type KS fuse.
The primary service voltage is 13.2kV L-L.
The lighting panel board will be 100 amp, 120/240V single phase
What is the correct method of calculating the short circuit amps for the given condition?
Thanks in advance for your help.
