Treg the electrician
- lynnwood washington
- electrician
residential... I have a 200 amp panel and some hvac equipment going in downstream. 15 kw strip heat 60/30 and a heat pump 25 amps . I plan to install 100 amp sub panel . what is a good calculation to determine if 100 amps is enough.
