Jordan_
- Los angeles
- Contractor
Hello, we have a dust collector that we recently replaced the motor on to a 3 phase 5 hp motor and connected it with a 1 to 3 phase VFD. We programmed the VFD according to the manufacturer but when it's on the parameter are a bit off
Our input is
3.7kw
230v
12 amp
3600 rpm
60 hz
but when the motor is running the VFD shows 60hz but only 1800rpm and when we measure the output voltage we see barely around 200v on two legs and ~195 on the third leg.
We get good suction but I'm afraid the motor is running underpowered
This is the motor
This is the VFD
I'd really appreciate any input on what might be wrong here!
TIA!
Our input is
3.7kw
230v
12 amp
3600 rpm
60 hz
This is the motor
This is the VFD
TIA!
