Keepyoucool2003
- Ohio
- Service Technician
I generally work on HVAC and controls, I do have my NEC book and it seems I’m hung up on disconnects. I’ve searched and the only related I found was a post where the OP was using an AC disconnect for a solar installation.
What makes an “ac” disconnect different than a general duty disconnect.
I point to the typical low budget ac disconnect with the pull out such as DPF222 and the molded case enclosed type such as QO200TR
The SD sped sheet refers to it in one section as an AC disconnect and later on the sheet, general purpose.
Are they mixing marketing terms with listed use?
Thank you.
Thank you.
