Hello,
I'm trying to learn how to size conductors for different HVAC equipment and I'm confused as to what to use as far as the following:
1- MCA/MFA = 1.9/15 @ 208/1phase/60 HZ. What current should be used to calculate the KVA? and what should be used to size the conductor?
2- MCA/MOCP = 58/70 @ 208/3phase/60HZ. what current should be used to calculate the KVA? and what should be used to size the conductor?
3- FLA/MCA/MOCP = 2.4/20,37/25 @ 208/3phase/60HZ. same question as above.
4- RLA/MCA/MOCP = 7.1/9/15 @ 208/3phase/60HZ. same question as above.
Thank you so much.
Thank you so much.
