Greg1707
- Alexandria, VA
- Business owner Electrical contractor
If badly written then perhaps not listed.Attached is the instructions for connecting a induction cooktop. I find the illustration to be confusing. Is there a difference between the two options?
However it appears that the white neutral isn't used by this device.The difference between the two is the first one is for an existing 3-wire feeder and the second is for a 4-wire feeder.
I never saw a cooktop that uses a neutral.However it appears that the white neutral isn't used by this device.
Repairing the DW ground removed the symptom, it did not fix anything. Dollars to doughnuts the DW does not have GFCI protection.I got to ask. I Went to a clients home were she was feeling a slight tingle, when grabbing the pan and touching the dishwasher. Found dishwasher did not have a ground ( was lose) Range a 4 wire. Was she feeling capacitance from current running through the Pan??? she said she never felt it till her new stove. Fixed ground and now its alright. Just wondering?
Sorry to Jack thread!
Very true. I've a hunch it's the DW and not the stove. A better EG at the DW would increase the Voltage difference between it and the range if it were a range problem.GFCI may not have been required depending on how old the home is.
