Rory Choicllroy
- USA
- elec Engineer
A 300KW pad-mounted transformer and a manual transfer switch will be installed outside the building.
From the external transformer to the external manual transfer switch on the primary side, it falls within the service entrance section.
For this segment, USE-2 cable is planned for the underground conduit.
From the secondary side of the manual transfer switch to the main electrical panel inside the building, THW or THHN/THWN cable is intended for use in the underground conduit.
I would like to inquire whether this setup violates the NEC (National Electrical Code) regulations.
