Cutima
- Philadelphia
- Teacher
I've posted here before and received help, so I'll give it a whirl again. I have an issue that has stumped three electricians and possibly the folks at Lutron. I have Ensenior brand LEDs installed in my house with reverse-phase dimmers from Lutron controlling them. When I use the LEDs on low power, AND I have a set of undimmed LEDs on a second circuit, AND I have a heavy load (fridge, coffee maker, air fryer, iron) on a third circuit, the third circuit always trips the arc fault.
Previously, I was experiencing trips on a circuit that had a heavy load on it (air fryer, coffee machine, fridge, etc.) in conjunction with a second circuit where the canless LED lights were attached to a forward phasing dimmer. Lutron suggested I use a reverse-phasing dimmer, which fixed the problem between the two circuits. They were familiar with this problem. However, now when I add that third circuit (basically when I turn an LED light on in a room without the dimmers like the bathroom) the second circuit--the one with the load--automatically trips.
I know the conventional wisdom is to check for shared neutrals, but this is a new build with a new panel and new wiring. Additionally, one of my electricians installed a plug right outside my panel with nothing else but that receptacle on the branch circuit. This circuit will trip if there's a heavy load on it in one of the above situations. I am assuming there's no way that this circuit could possibly have a shared a neutral with any other circuit due to it having its own dedicated wire coming right out of the panel.
Any suggestions here on what the interference might be? I realize that this forum is for certified electricians, but I would love to provide some advice to my electrician. I don't think he'll be coming here on his own.
