mtnelect
HVAC & Electrical Contractor
- Southern California
- Contractor, C10 & C20 - Semi Retired
Are you saying that he should have disconnected it? Isn't the drop under the control of the POCO? A sparkie shouldn't be climbing the pole and disconnecting it.
I don't really see a problem. POCO leaves live but taped off service drops all the time.
????. That's not electrician problem. The power company is in charge of there meters they should know if there meter are still in use. I don't quite grasp the gripe. Who cares if he abandoned the job might of been a headache, If what he touched did not damage or left dangerous, how is he responsible for a Utility? every one trying to pass the buck, terrible.
The power company is that dumb to not see a load usage or property owner that dump to still get charged two meters, knowing one is not in use., either way not electrical fault.
I know that this forum is set up as a resource for the electrical trade, but also as good business practices. Having a dispute with the customer, I have a hard fast rule, The customer is always right, just packing up and abandoning the project, in my opinion is not right.
I would like to hear the contractor's side of the story. Seems to me like all the customer has to do is call customer service, tell them that the service is no longer in use, stop billing and have them send someone over to check it out. Real easy to not get off their a** and blame everything on the contractor.
-Hal
Clearly we don't know the whole story, and this seems fishy. So There were two service drops each feeding different meters on the same building? That is extremely unusual. Did he do the combining or leave the one meter unenergized? What didn't he finish?
This contractor did that but failed to go to water & power and clear it with them. No, spot request, no agreement signed in regard to solar power sharing. When he discovered that he started the project without any approval, he left.
Easy to say, hard to do. It's not like there's a list, "Crappy EC's to Avoid". Calling previous customers? How many here want to talk to a stranger out of the blue calling about work you had done on your house?So, you expect that a contractor like this is going to care about taking care of the customer? Maybe the customer should have done some due diligence before they hired the guy.
-Hal
So they had two service drops, one feeding each meter?In regard to consolidating two meters to one. The first meter was for a ADU and the second meter was for a house. The owner wanted to combine the two meters to one.
Contractor is probably used to working in IOU territory.
If you’re that dumb to not do your research when your spending your money that’s your fault. You can’t walk through life with blinders on or we get to we’re we are now lolCorrect ...
The state is having an inrush of solar complaints:
1) High pressure salesman promising free installation and free power
2) Using finance companies that pay the contractor upfront before project is started
3) Using "PACE" to pay for the installation that shows up on your property tax bill
4) The state has set up a fund to compensate customers that have been taken advantage of.
Oh I see, this is an anti solar thread. Got it now.Correct ...
