- New Jersey
- Journeyman Electrician (retired)
This is sort of a rhetorical question but I have a 15 amp homerun circuit for a hot water boiler that runs all the way to the boiler room in a house. In that room a tankless HWH is being added which requires 120 volts. The boiler draws about 2 amps with the pump running and all the zone valves operating. The HWH draws less than 1 amp. The service will be backed up with a portable generator with an interlock so only certain critical circuits running on gen power. With both on one circuit it would make it simpler than adding the HWH to the existing general purpose circuit. Who would put them on the same circuit?
