JJWalecka
- New England
can the black annealed tie wire be used as support for light fixtures? i have seen contractors use it a few times whether legal or not
what would be the difference between listed ceiling wire (same as ceiling guy uses) vs black anealed tie wire? is there a fire rating on listed cieling wire? is it the gauge of cieling wire? thank youProbably same wire type, yes, but not wires installed to support ceiling.
I was referring to the rule that you must install your own wires, and not use grid support wires.what would be the difference between listed ceiling wire (same as ceiling guy uses) vs black anealed tie wire? is there a fire rating on listed cieling wire? is it the gauge of cieling wire? thank you
