Hi All,
I am a little confused about a few things...
1. I met with an Electrician who told me he could fill a conduit with up to 20 current carrying conductors (table 310.15(C)(1)) and still use a #12GA wire on a 20A CB because the load for the receptacles is so minimum and 12GA wire at 90C is rated at 30A (after derating 15A). Is that true? My understanding was that the derated size still needs to be greater than your receptacle / CB size (were using 20A). I am having trouble finding the concrete answer though.
2. If most 20A breakers are rated for 75C that means my wire needs to be rated for 75C as well, correct? I am having trouble finding what receptacles are rated for. However, if breakers are at 75C then based on Table 310.15(C)(1) the derating for a 12 guage wire at 50% would actually be 12.5A. My mentor taught me to always size wire at 75C... with this issue, I guess I am a little confused at when I can size wire at 75C or 90C - if anyone has a resource for that or correct code section to look at I'd appreciate it! I feel like I am missing the obvious here, Ha
Best!
Best!
