timmermeier
- alton il
- electrician
Where in the 2017 code can i find ground rods. my book is missing !Can i use a 3/4" galvanized pipe 10' long for a ground rod 2011 nec. when did the nec start letting you do this?
And it is used as conduit. If it looks like a duck and quacks like a duck...No, it merely resembles conduit.
Almost anything can be used as a conduit.And it is used as conduit.
Maybe it's a duct.If it looks like a duck and quacks like a duck...![]()
it is not used as conduit. it is used as a raceway but conduit and emt are just two types of raceways.And it is used as conduit. If it looks like a duck and quacks like a duck...![]()
If it's missing how does someone pointing to the article section help you read it? Probably need to bite the bullet and purchase another one or go through the painstaking task of using the NFPA free view.Where in the 2017 code can i find ground rods. my book is missing !
