I have a Greenlee heating blanket used for larger conduits. It takes a little longer than a hotbox, but it heats more of the length so you have much larger sweeps. I think most people use propane torches today to heat their larger conduits.Something I haven't seen for a long time is the old Greenlee motorized pvc bending oven boxes. You can stick a few lengths in depending on size of conduit and let the machine run and you will have noodles after a bit of time in that machine. It rotates the pipe while heating it. I don't know if Greenlee still sells that machine , but it was really handy for keeping up with the brickies on a jobsite .
I looked on Greenlee's website last night. They have 36" ones. The ones I was talking about were 8 feet long . There are some tricks. You don't always want an entire length of pipe as a noodle so we would just shove a bunch of 3/4" in there about three feet into the machine so we could move riser pipes back and forth in the block walls if needed.I have a Greenlee heating blanket used for larger conduits. It takes a little longer than a hotbox, but it heats more of the length so you have much larger sweeps. I think most people use propane torches today to heat their larger conduits.
U are thinking of bell ends that go on the end of a PVC run, where it protects the wire when pullingOh ok I’m aware of that but they also sell end bells that you can put on the end of the conduit . My confusion sorry
I have done not know hotoven box of recentAnyone know of the still use those oven/hot boxes?
I was responding in a like manner to this -
Oh, in that case . . .I was responding in a like manner to this -
I have an old 8 foot baseboard heater and a U shaped piece of sheet metal I bent as a cover that I use if I want to heat up longer segment of PVC. Call me hack if you want - it works though.I looked on Greenlee's website last night. They have 36" ones. The ones I was talking about were 8 feet long . There are some tricks. You don't always want an entire length of pipe as a noodle so we would just shove a bunch of 3/4" in there about three feet into the machine so we could move riser pipes back and forth in the block walls if needed.
rackateirs makes one like it but its basicaly a chunk of gutter with a hole for a heat gun. probably something thay started as a field built invention.Something I haven't seen for a long time is the old Greenlee motorized pvc bending oven boxes. You can stick a few lengths in depending on size of conduit and let the machine run and you will have noodles after a bit of time in that machine. It rotates the pipe while heating it. I don't know if Greenlee still sells that machine , but it was really handy for keeping up with the brickies on a jobsite .
I know I need to check spelling better …sorry.I was responding in a like manner to this -
You posted this after I made a typo lolI know I need to check spelling better …sorry.
I have one plant I regularly do work at that has steam, always wanted to see how well it would work, and bet it would work pretty well, for bending PVC.Don’t know if this has been mentioned. Old company used a water/antifreeze system from green Lee I believe worked wonders fastest pipe bending ever. And does not burn pipe
I remember using 20' lengths of multiple sizes on a school project back in the late 90's or very early 2000's (left the field in 2001) and I am sure they would have been listed than. I am sure the school system would not allow non UL listed items on the project.AFAIK they are not listed, unless that has changed more recently.
Is buying one of those shrink wrapper tools cheaperI got this about 15 years ago. I bend a lot pipe on my pool projects. I have been able to bend a 6" piece of Sch.80 PVC. Took some time but it worked.
I never knew the origin of this tool other than someone stumbled on the fact it bends PVC. It wasn't until about 5-6 years ago an employee recognized it as the tool the shrink wrap boats at a marina he had worked at.
I just need a 20 gallon propane tank and I'm good to go.View attachment 2569278
Hotbend - The Revolutionary Tool for Bending PVC Pipe!
The HotBend heat gun is a revolutionary tool that will save you time and money on any underground project that requires bending PVC pipe!hotbend.com
