- Tennessee NEC:2017
- Semi-Retired Electrician
I'm not a motor guy so I know little about the different types. I know some that require start & run capacitors for single phase. My question is what type of single phase does not use the capacitors, and how do they start?
I have a small motor for a bath fan that has started stalling, or not starting. Sometimes it will come on full and just stop after a minute or so. Then sometimes it won't start at all. You can leave the switch on and it will eventually start. I've ruled out the switch and wiring. I would rather just replace the motor and not have to tear out the whole fan. The tag on the motor is faded so I don't know the size or type motor to buy.
I guess I'm asking if there is any way to fix the motor, or what type motor would be needed for replacement?
