VirutalElectrician
- Mpls, MN
- Sparky - Trying to be retired
I don't have much experience with these as I don't do any new commercial stuff...But looking at a house that's going to have a 800sq open basement. The client doesn't have any vision for the space as of yet, but wants to do some future proofing...So looking at doing a grid of 6-8 in floor concrete boxes with 120 and data in them.
In researching products, I like the Leviton series, it has a nice divider down the middle to split low/high voltage, but it's $60 for a box, $25 for a leveling ring, and then $200! for the cover plate! So basically $300 per box plus PVC conduit and labor.
Bryant boxes are surprisingly more reasonably priced, but none of their boxes seem to have any low/high voltage divider.
The Arlington series is more reasonably priced. $30 for a box, $20 for a leveling plate, and under $100 for the cover plate. The problem with these boxes is that the low/high voltage divider cuts across a corner, only allowing a small corner for the low voltage, making it impossible to pass-through the low voltage to the next box, necessetating the need to run conduit to each box for data.
Hubbell System One...Similar to Leviton...Starts off nice and reasonable, then you get nailed $200 for a cover plate!
Legrand/Wiremold has a system similar to Leviton, but the floor plates are a bit cheaper at about $140 each.
Anything I'm missing?
