samthebikerider
- Portland, OR
- Building Scientist
Preface: I am a researcher who is hiring contractors across the US to install 120V heat pumps and heat pump water heaters
I've had some pushback from electricians in various corners of the country regarding installing 120V heat pump water heaters on shared circuits. Some say their AHJ will take issue, and some have seemed to not notice a problem. The question is: can 120V HPWHs that are designed and UL-listed for use on a shared circuit be installed on a shared circuit according to NEC? The concerns are that dedicated circuits are required for "critical-use" equipment, and electric water heaters fall into that category. I haven't found the code references yet, and surely this will be somewhat AHJ-dependent, but what are the general thoughts? UL and manufacturer approval is good enough to not worry? With the recent and ongoing push to bring 120V heat pump equipment for water heating and space conditioning to market, I see this question breaking out eventually.
Example product: https://images.thdstatic.com/catalog/pdfImages/08/08663254-cda3-4820-bc09-2789a7a20b2e.pdf
