Product knowledge
Murphy79
Kansas City , MO
Master Electrician/ Elelectrical Contractor/Instructor/ Solar
Hey guys I'm working on a commercial project installing solar. Does anyone know where I can find Polaris Taps rated for a thousand volts, ideally I would like the four multi-tap. I can't find them anywhere. I need them because I have PV circuitry that has 2K volt conductors and I need to make spices because the arrays are on two different buildings. If anyone knows where I can find them please direct me in the location. I tried Gordon Electric but can't find anywhere else. I need 12 of them. In case I don't get a chance to check the form again please email me at keith@lifetimesolar.com... thank you and appreciate it.!
Check out GEL TAP SPLICE - 1000V (GTAP) There is not a lot available. Your other option is to use something like an H crimp and insulate it properly for the voltage.
Not sure what you mean by "PV circuitry that has 2K volt conductors". What is the max string voltage in the array? 1000V? 1500V?
