wexcellent
- Portland, Oregon
- Inside Wireman
We have to disassemble and move about a 100' overhead run of six 6" RMC raceways. Looks like RMC weighs about 180 lbs per 10'. I helped run 5" RMC years ago but it's been awhile. Just curious if anyone with some decent experience can share any useful tricks to make unspinning and spinning easier. I was thinking that if I shimmed up the piece being uninstalled/installed just a 1/16" off the strut and then fabricated some rollers I could shove up against the pipe on either side and tighten in place before removing the shim it would make it so that the only thing I was fighting was the threads. Also thinking about using some kind of lube on the threads for the reassembly.
Open to any useful suggestions/insights.
Thanks!
Thanks!
