102 Inspector
- N/E Indiana
- Inspector- All facets
As an inspector, I reviewed and approved an electric meter installation as 200 Amp overhead service. Typical installation with panel directly behind meter inside the dwelling under construction. Phase conductors properly landed in panel and meter base, grounded conductor properly landed and grounding completed by 2 ground rods. Bonding screw properly installed. Electrician called this morning and indicated he was getting readings of 120 V on one phase and 208 on the second phase which apparently burned out a circuit board on a furnace. Phase to Phase he said was 240 V. It sounded like a grounded conductor (neutral) was lost, but I always thought that in that case the total of each phase would add up to the 240V expected. Why would one phase show 208V. Trying to learn, not blame.
