CCA wire or some other kind?
Dan120
Florida
Journeyman Electrician
Hello, could someone tell me what kind of wire this is I’ve seen it in a few houses and I cant seem to find what kind of wire it is. looks like NM but it has a cover ground? On the insulation it says NM-B-2 but I cant find it online?
In the second picture there appears to be a white wire missing, if that’s the case it could be NM but from Canada. I believe they make a black red NM cable
If it is marked NM-B then it is NM-B... My last house had some NM cable like that. I think it was installed in the 60's and the ground was insulated green instead of bare. Not sure who makes it. I think is was old enough that the ground was also 1 size smaller than today (#16 ground in a 14-2 NM cable).
This a newer house, maybe built less than 3 years ago, I’ve seen different types one with a neutral and some without, also the wire size is a 8 AWG in a orange sleeve. I will try to take more pictures the next time I come across another one and post them here.
It looks like Copperweld NMB to me but I don't see where they offer it without a white wire.
Actually the spec sheet doesn't show conductor colors so I have a feeling 8/3 is Black/Red/White/Green and 8/2 is Black/Red/Green.
I thought Copperweld was steel core copper wire used for antennas?
With the CCA they're pushing the ampacity to color size so 12awg is white and 10 is yellow ect.
This is the reason why I was under the impression that it was CCA, I keep on seeing the wire i newer houses I just haven’t been able to have with legible markings.
