DukeSilver
- California
- Electrician
Thank you for the advice. I found this after a contractor installed new 2 x 4 fixtures. Feels like there’s a bunch of violations here. Do you happen to know what actual code is?Use a metal 1G old-work box.
It's most likely line voltage if it mimics power loss.. . . I’m not sure if the push button is 277 or 24
I believe they feed a bulb or LED.I would like to see what the two red wires are for.
As Larry stated those are for the indicator lamp and it should be installed so that it is visible from below the ceiling.I would like to see what the two red wires are for.
Take your pick here is a few for starters:Do you happen to know what actual code is?
Looking closer at the pic. It's the battery ( red wires) connector leads. Pretty sure there low voltage. At first they looked crimped.I believe they feed a bulb or LED.
