marmathsen
- Seattle, Washington ...ish
- Electrical Contractor
When you have PVC entering some sort of box or other enclosure outside (top or side entry), do you seal the the TA to prevent water intrusion? LFMC and LFNMC connectors both come with sealing O-rings, but PVC TAs don't. Do you buy them separate and install them? My supplier seemed totally confused when I asked for some, and needed to special order them. He sold me sealing lock nuts instead which appear to be designed for RCM and IMC. Do the sealing lock nuts compress against the threads and actually seal out watter? The o-rings compress between the lip of the connector and the enclosure which seems like a better seal.
