Solar_ice_caps
- Florida
- Solar EPC
Looking at your common Aluminum FMC.
We have attic runs that go between a roof-mounted junction box and a (side of house) wall mounted combiner box (panel).
Run length and circuit size independent, we have to run a green EGC for solar installs.
This run is often between a plastic combiner box and a plastic OR metallic junction box on the roof.
In the former case, I bond both ends of the run with insulated bonding bushings.
To my question:
Sometimes I need to add a box in the middle of the run to bring in another circuit, or because I want better mounting/access in the attic. Suffice to say now I have a FMC run with a metallic box in the middle. The box is connected via either screw-in or squeeze connectors, which is where I'm starting to feel iffy about the bonding. Neither of those connectors have any kind of penetrative bonding feature that I can tell.
Am I required to use bonding bushings in this center jbox? (keep in mind, again, that there is an EGC already in this run, so I am not using the conduit as a system EGC, I'm just wanting to bond the conduit properly and safely.
Thanks as always to this ever-helpful forum.
To my question:
