The Magical 1-Wire Receptacle
Seven-Delta-FortyOne
Goin’ Down In Flames........
Humboldt
EC and GC
Guess that’s one way to do it, if you’re really that lazy 🙄
Commercial remodel I’m doing. So much bootleg wiring in one place, it really boggles the mind.
During demo today I was trying to determine where a conduit with 2 conductors went. It was live when I started, I’ve demo’d about 80% of what was there.
Put a tracer on the wires, and it seemed that they dead ended in a structural header. 😳
I finally removed drywall and found a notch made in the header, and the conductors dead ended in the header, with tape over the ends.
Roads to nowhere. I’ll never know why 🙄
I've seen a neutral used to bootleg the ground, but never the ground to bootleg the neutral.
I have, I was installing buss way for a sewing plant to feed the machines, the existing was 240 volt receptacles on the floor for each machine. The work light on the machines was 120, so they used the conduit as the neutral! A lot of burnt locknuts were found when I ripped it out!
What is structural header
Never seen an old circuit like that with a red conductor and no white conductor. That why I thought of just a staight 240 volt circuit that was converters to 120.
I feel your pain.
Doing some demo today.
It a complete gut.
