Appreciate the info. Right now I don't have a choice regarding 708. Maybe when the construction estimates come in, things will change.You can use
or regular conduit & wire in a 2 hour rated soffit/enclosure.nVent PYROTENAX Home
nVent PYROTENAX fire resistant building materials meet the NFPA standards and safety codes, and protect your building during a fire emergency.www.nvent.com
First I suggest you try to avoid Article 708 like the plague and be sure you really have to follow it. It is a PIA.
I agree! I have my doubts that anything could be built to 708 and pass to the letter of the article.First I suggest you try to avoid Article 708 like the plague and be sure you really have to follow it. It is a PIA
The requirement to comply with 708 is found in other codes and standards. 708 only tells us how to install it when it is required by other codes and standards.I agree! I have my doubts that anything could be built to 708 and pass to the letter of the article.
Hopefully that requirement will be removed when the bids come in.
I do not believe there is an adopted code in the US that requires 708.The requirement to comply with 708 is found in other codes and standards. 708 only tells us how to install it when it is required by other codes and standards.
What type of installation is this?
Or someone preparing for Armageddon.I do not believe there is an adopted code in the US that requires 708.
My understanding is that it only get implemented by a contractual requirement or a rogue AHJ. Even when it is a contractual requirement, in my experience they back down when they see the cost of design and construction.
