Well, most soldered points for supply wiring will pass through the component board and bend over to the solder point, effectively mechanically securing the wire to the board with the Z offset of the wire, thus sort of fitting the 110.14(B) "mechanically" secured but would fail the "electrically" secured . But most if not all these soldered connections are part of the mfg. process and covered under the product "listing", and not a field connection, thus exempt from NEC.IMO soldering an LED strip has nothing to do with 110.14.
Field modification, "unless instructed by the mfg. and allowed", would have implications related to its "listing" and could be from that view a code issue.
So what is OP trying to do, a field modification, or a repair?
Don't ask/don't tell.Do the mfgs instructions allow for soldering?
- Verify that your strip light is acceptable for use in wet locations by looking for a “approved for wet location” label on the outside of the product packaging. Remember that only the strips are approved for wet locations (power supplies and connectors are not approved unless stated). Cut strip to length, then, using a razor blade, carefully remove the silicone jacket to provide access to the copper solder pads. Solder your wires to the strip(s). Fill an end-cap with silicone and carefully slide the end cap over the wires (you may need to poke small holes for the wires) securing it firmly against the strip light. Wipe off any excess silicone and allow to dry before connecting power or submerging.
Great looking soldering station. Can not remember what solder combination had the lowest melting point. Know it's not 50/50 but thinking 60/40 or think they made a combination between these two. Got some home made cookies a few times when I used to bring in my 25 watt soldering irons solder the link on charm brackets when they were popular back in the 1970's.Soldering guns have given way to soldering pencils with heat-controlled tips! The tip on a soldering gun is about 1/8" square by 1/4" deep-- lots of heat for big clunking circuit boards! It would bridge at least 3 leads on an integrated circuit! I haven't used mine in decades. Literally.
Radio Snack used to sell a soldering station with a needle-point wand that plugs into a base station. The one I have looks similar to this one. It lets you assemble teensy-weensy things. I have the magnifying headset I use to see the teensy-weensy things.
60/40 (with lead) is still available.60/40 was standard for electrical soldering, plumbing solder was usually 50/50. The higher the tin content (first number), the lower the melting point.
Of course, no more lead these days….
63/37 is the 'best' blend; 60/40 is close. don't know why it is easier to manufacture.
