Im looking for some help understanding positive and negative VARs. I'm also dyslexic so this greatly complicates the matter.
My original understanding was that adding positive VARs was the same as adding capacitance to the circuit and adding negative VARs was the same as adding inductance. I think this was due to my understanding that added capacitance to an AC circuit will cause a leading power factor and adding inductance will cause a lagging power factor.
Is is actually correct that adding capacitance to an AC circuit is adding negative VARs and adding inductance to an AC circuit is adding positive VARs?
If so a 'VAR' (Volt Amps Reactive) could be more accurately be thought of as a 'IRVA' (Inductive Reactive Volt Amps)? When thought of this way, adding capacitance would be the same as adding negative IRVAs. I don't expect that the naming conventions will be or should be changed to match my way of thinking but I thought this could help someone elses understanding of the concept.
Assuming my understanding of the above is correct, adding negative VARs (adding capacitance) would usually have the effect of raising voltage levels due to most grids having some degree of a lagging power factor. By adding the capacitance, the lagging power factor is brought closer to unity. This in turn will raise the voltage levels because of the overall impedance will be lowered and voltage drops will be less in the transmission lines. To bring it all together, in most cases, adding negative VARs is likely to increase voltage levels.
If my understanding of the above is true, why would a utility request that voltage triggered reactive power correction would supply negative VARs when a certain voltage level is exceeded?
To state this another way, they are requesting that when the voltage level exceeds 109% of nominal, -44% VAR is to be injected.
My confusion is, would this not only add to the overvoltage condition?
Wouldn't it make more sense to inject 44% VARs to lower the voltage? I understand this would likely make the power factor worse but it would also work to lower the voltage.
Any feedback on this would be much appreciated.
