Ecoflow Delta Pro 2 lithium battery/inverter acting as a UPS to a 6 circuit, Reliance transfer switch. The Ecoflow is plugged into a dedicated 20 amp outlet next to the panel to stay charged. I believe the GFCI is tripping because the Reliance panel doesn't switch the neutral.
Since the outlet is in a garage, removing the GFCI isn't OK. A grounded 3 to 2 prong adapter doesn't seem correct either. Or can the Reliance be modified to switch neutrals? Is there a code compliant way to have this system work properly? Or abandon the UPS feature and only power the Reliance panel during an actual power outage?
