Alexis Enrique
- Miami, FL
I'd guess that one of them is a feed out to another, equally scary pole.do you think the short pvc is the switch leg?
"The screw has to be green? Give me a break. Just use a drywall screw and you're good to go"."Lights come on so what's the problem?"
Get that questions all the time.
"The code is just a bunch of bureaucratic B*" or, "It's just the "Man" getting in the way of me doing what I want.", is another one I get as a responce to the reason given for the first.
Screw has to be green is a somewhat common misunderstanding. Only screw NEC requires to be green is if said screw is the main/system bonding jumper in say a panelboard, fused disconnect, etc."The screw has to be green? Give me a break. Just use a drywall screw and you're good to go".
That’s the mentality that the company I worked for had. Just because they were at a mine site that wasn’t regulated by NEC the owner and his sons would demand their electricians to do unsafe work such as burying SOOW cord, using it as a feeder to shipping containers converted to employee housing, and splicing the SOOW wires with wire nuts without a box.Came across this, there is not need to follow NEC to make it work. But how people can do this, this is a public place, 3 feet from side walk, this is for a business sign.
Murphy, perhaps?"An accident waiting for a place to happen will, given time, find that place." (Famous saying by some famous guy.)
Canadian boxes always come with a bare metal screw and the Iberville ones are really wide pan heads instead of hex so you can get the wire in with a lot of surface area.Screw has to be green is a somewhat common misunderstanding. Only screw NEC requires to be green is if said screw is the main/system bonding jumper in say a panelboard, fused disconnect, etc.
General purpose "grounding screws" we purchase for use in general use metallic boxes usually are green, but nothing requires them to be green.
Terminal screws don't just have wide heads; there's a groove cut on the underside of the head to urge the wire toward the center as it's tightened.Canadian boxes always come with a bare metal screw and the Iberville ones are really wide pan heads instead of hex so you can get the wire in with a lot of surface area.
