jaggedben
- Northern California
- Solar and Energy Storage Installer
If self sustaining arcs are possible at 120 volts, why does 230.95 only apply to systems over 150 volts to ground? When that rule went into the code, the reasoning was self sustaining arcing ground faults do not exist below 150 volts to ground and so a 208Y/120 volt system does not require the ground fault protection that is required for a 480Y/277 volt system in 230.95 and various other sections of the code.
Okay, but a '*self* sustaining' arc is a different category and AC systems with NEC wiring methods are a particular subset of circumstances. Whereas when controlled by the right hands (such as mine a few years back) a stick welder can sustain an arc at a much lower voltage than 120. And 120VAC can cause arcs, and various things can sustain that even if the arcs are not 'self sustaining' ones. I was responding to what seemed like an inaccurate over-generalization.
