LarryFine
- Henrico County, VA
- Electrical Contractor
When it only carries imbalance current, such as the neutral of a center-tapped 1ph or of a 3ph wye, it is considered to not contribute heat, because any current it carries is current not being carried by one or more line conductors.Code defines Neutral conductor as "the conductor connected to the neutral point of a system that is intended to carry current under normal conditions." So not sure how the code is says its a CCC and yet says we don't have to count it as a CCC.
