Installer
- DesMoines, Washington
We have to bond a polyphaser bonding conductor to a building column. My team is concerned that the cadwelding process will heat the beam up and ignite combustible materials like drywall, OSB or insulation in the vicinity of the beam.
Then fire alarms will go off and part of the building is an elderly treatment facility and evacuation would be problematic.
This is a pretty hefty beam and the cadweld process is an instant of high heat. Would the steel would dissipate the heat quickly or slowly like if we were using a torch?
