superbreakers.com
Look on Platt Electrical Supply!I am trying to find some thing compatible
Square D 8903LO40V03 Lighting Contactor
8903LO40V03 - Square D Lighting Contactor Schneider Electric / Square D Lighting Contactor Its Compact And Easy to Install Standard Nema Construction Four pole and Electrically held with Screw Clamp Lighting Contactor. Lighting Contactor has "220 V At 50 Hz 240 V At 60 Hz" coil voltage rating...superbreakers.com
Any 4-pole contactor with a 120 volt coil will work. If you get the exact same one that's even better because the mounting holes might even line up.We have an account at the company I sent the link from. It looks like off the ratings they are the same
