reyamkram
- Hanover park, il
I have five to 200 amp disconnects each disconnect the neutral and ground are bonded and these are the service disconnects and then they feed individual 30 amp pedestals in RV Park question since the neutral and ground are bonded at the disconnect I should not Bond each pedestal would that be correct
At the same pedestals if there is a ground rod at the pedestals do I not Bond the neutral ground near the pedestals if a groundwater is installed or do I Bond the ground in neutral at the pedestal at the ground rod is installed
Thank you all for any and all information it's very much appreciated
