I have a dual motor compressor that I am wiring 480 volt 15 Hp 3phase. The control box has two separate contactor/overloads installed in. I have sized both motor disconnects , fuses and wiring size as per the NEC. I am feeding both disconnects with a single 100 amp feeder due to not being able to get any other breaker in time frame we have.
My question- Is this is the correct way to do this? I keep thinking that since it is a single unit with a single control panel I should be able to feed it with a single disconnect but I do not find where I can do this? Thank you
