fishingmaniac
- Hull, Mass
I’m guessing somewhere in the 1960’s but I’m curious as to the code year.
Someone told me they believe their house was completely rewired, knob and tube removed, in 1981. I’m looking at a lot of 2 hole receptacles and cloth Romex which may (or may not) only have that tiny ground that tends to break. I also wonder what year that changed to a full size ground. I believe The code has wavered a couple times on changing any 2 prong to 3 prong when using a GFCI receptacle or breaker upstream. I don’t believe you should do that giving someone the impression of a good ground when there is none. There must be a good thread here on all that somewhere.
