SparkyAdam
- Oregon
- Electrician/Small Business Owner
Hello Forums,
I have a customer building a house who has specified the exact outdoor plug cover he wants. The problem is that the plug he wants is an industrial-grade plug that is washdown and wet location rated but is not an in-use cover. The plug he wants has an associated cord end that it is meant to be used with, and so far as I can tell, the plug cover would not be wet-location (or even weatherproof per 406.9) rated if he were to plug in an everyday cord.
This makes me suspect that this would fail inspection because the inspector would assume that the homeowner would be plugging in a normal cord, and therefore, this would not meet the standards for weatherproofing set out in 406.9(B)(1).
However, he is quite interested in this being his outdoor plug-in, so I figured I would solicit the community. Am I wrong on this one?
The cover:
www.hubbell.com
The cords end it goes with:
www.hubbell.com
The cover:
Watertight Series, Straight BladeReceptacle, 15A 125V, 2-Pole 3-Wire Grounding, NEMA 5-15R, Yellow | HBL60W47 | Hubbell Wiring Device-Kellems
Straight Blade Devices, Thermoplastic Elastomer Water Tight, Industrial/Commercial Grade, Straight, 2-Pole 3-Wire Grounding, 15A 125V, 5-15P. | HBL14W47A | Hubbell Wiring Device-Kellems
Straight Blade Devices, Thermoplastic Elastomer Water Tight, Industrial/Commercial Grade, Straight, 2-Pole 3-Wire Grounding, 15A 125V, 5-15P, Yellow, Single Pack.
