If you can find a relay with a coil voltage that works on the interconnect wire's voltage, you can use the contacts to trigger anything.
There's one!Google kidde sm120x
We use those.Google kidde sm120x
That or a security system that will trigger alarm/trouble alert if it detects high noise levels kind of accomplishes this as well.If you can find a relay with a coil voltage that works on the interconnect wire's voltage, you can use the contacts to trigger anything.
