Jimmy7
- Boston, MA
- Electrician
I know I could have did this a different way, but now I’m curious of the derating and current carrying conductors.
One single pole and one 3-way for basement lights in an unfinished basement on a 15 amp circuit, all conductors in the conduits are #12.
Top left box has 14-2 feed, and a 14-2 that goes to a garage light. The neutrals in this box are spliced and there is a white dropped down to the switch location. The two black wires are dropped down for the single pole switch, and I also dropped a ground wire.
The top right box has a 14-3 for a 3-way, and a 14-2 that goes to a basement light. From the 3-way switch at the bottom, I have a feed (Hot and neutral) a common, two travelers and a ground that goes up the conduit on right to the 4” square.
What is considered a current carrying conductor when you’re sharing a conduit with a feed and conductors used for a 3-way switch?
Thank you
Thank you
