dm9289
Industrial Maintenance Electrician
- Pennsylvania
- Industrial process repair/ maintenance Electrician
At the factory I work at we have a 480Y feed from utility. We run many 1980/1990s DC drives and I believe these transformers may be for isolation. Original Engineers are no longer with us.
Questions does a delta/delta transformer have a problem being fed from a wye?
If it is ok to feed delta/delta with a wye would the output of transformer act as a delta?
I assume yes?
There is a small dash symbol by H1 and X1 what does that indicate?
Thank you for your help and patience
I assume yes?
