Eddie702
Licensed Electrician
- Western Massachusetts
- Electrician
Anyone use the Klein E-450 tracer kit and if so, what do you think of it. I would expect to use it for tracing Romex in residential more than anything else?
I just did.Did you read the reviews on Amazon?
That one is better but obviously at a premium priceI can recommend ideal 65-957 . Used on eBay around 500$
Can you please elaborateNow if you don't read how it works and end up just doing a non isolated ground and not disconnected nuetral your signal won't have a proper antenna so you need to be smart about what you're hooking up to. This applies to a dead short also
They're in the instructions. With pictures. I'll try and post them tomorrowCan you please elaborate
I have not found it to make much of a difference in the signal on the cable. If anything, running to a separate ground can put a signal on grounds all over the place! That is with other manufactures, but same concept. YMMV
