mtnelect
HVAC & Electrical Contractor
- Southern California
- Contractor, C10 & C20 - Semi Retired
My purpose was to "Shake Up" our understanding of the principles of grounding ...
You are correct about differences between investor owned and public owned utilities. We are all public owned throughout this state, and most are very good about focusing on performance of the system and do perform a lot of preventative maintenance instead of just waiting for some things to fail before fixing them. They also do project future needs as best as possible and try to have infrastructure to handle those needs when needed vs scrambling to be able to handle those needs after the need has arrived.I'll guarantee that most utilities are more concerned with MAKING MONEY and keeping just inside the reg's than anything else, including "stray currents". (Investor-owned will act differently than publicly or customer owned.)
Where's the business case for a massive renovation of the transmission and distribution systems? And I don't see this sort of change as a reliability enhancement, if it is, how?
Have we heard the engineers who design and maintain these systems chime in about what such a massive change would entail and improve (other than making a lot of work and enriching the copper companies)?
Heck, I'd just like to hear about where and how often the use of MGN causes actual, not perceived, problems. As mentioned above, dairy farms, around some bodies of water, inc pools, but how does that compare to the rest of the service area? Does it make sense to move away from MGN in specific areas or everywhere? (If a county has one lake with one dock and no livestock farms, how much sense does it make to re-engineer the entire distribution system for that county?)
That helps with on site issues but won't stop rise in voltage on grounded conductor because of voltage drop on primary neutral.I think we should transition to all loads being line to line. Over time the neutral load fades away.
Capacitance is a thing.I don't know much about distribution in general, but I read in a really old book from 1922 that the long distance lines were grounded because otherwise huge charges were building up in the system to the point of large arcs being thrown off generator terminals, even some mechanics at central stations being zapped. Insulation was failing prematurely due to the huge voltages. Apparently there is a lot of field potential spread across the planet that you only notice over long distances. The brand new transmission lines of the time were long enough to stretch across areas of varying potential and charge could build up. The solution was to ground the system periodically along its route. If that is indeed true, we may not have much choice if we are to have an electrified world
Anyway, lots of people, maybe even the vast majority, never have problems with/from the utility MGN system and don't have to deal with "all of this 'Stray Current' floating around everywhere"...
Yeah, I know this issue seems to really keep the OP up at night, but how many people have actually had a problem resulting from a MGM distribution system???Yeah. I grew up on it, and I'm kinda used to it. Plus, I have never encountered a problem with it.
Technically speaking, it's "none of our business" what the POCO does before the power hits the service.Yeah, I know this issue seems to really keep the OP up at night, but how many people have actually had a problem resulting from a MGM distribution system???
NEC has been there for an eternity. Other countries developed their own and also think their system works. We have been following NEC and we think we're covered. What's new?unless everyone used ground fault protective devices on pretty much everything you would still have current on the grounding conductors any time someone didn't "follow the rules" or had unintended current on the grounding conductor.
You would still have bonding at every separately derived system and chances of stray currents should something go wrong.
I still think things like swimming pools should require equipotential bonding even if such distribution were utilized, problems won't be as bad but still is possible to have voltage gradients within the pool.
Can that be transformed for a free, electric fence?I only noticed this because when I connected the grounded service conductor it sparked when making contact with the lug - the grounding electrode was already in place.
Except there is almost always a small amount of voltage to ground because of voltage drop on the grounded conductor.Technically speaking, it's "none of our business" what the POCO does before the power hits the service.
We are presented with a grounded circuit conductor that establishes the zero-volts-to-ground point.
