Seven-Delta-FortyOne
Goin’ Down In Flames........
 - Humboldt
 - EC and GC
We don't have any Square D up here, its all Eaton, so I rarely work with it.
I have a 200A Homeline with the 4 space backfed breaker that I need to install an ATS. I want to move all the branch circuit wiring out of the meter/main, put them in a sub panel, and reuse all the breakers.
I'll feed the ATS from the load side of the MCB.
I use the Eaton BRPFS225 lug kit in these situations, like this, when I'm working with Eaton:
Eaton BRPSF225 - New Sub-Feed Lug Block$126.29Coast to Coast BreakerFree by 5/2130-day returns (most)
I'm looking for the same for the Square D, and I think I found it, but I just want run it past the guys who work with SD first. I found these, one looks like a feed through lug kit, one appears to just be a 200A 4 space breaker, which is actually cheaper than the feed through kit:
Or the breaker:
Or the breaker:
				Square D 200 Amp 2-Pole 120-Volt/240-Volt Mini Branch Circuit Breaker Allows Up to Lifetime Warranty HOM2200BB - The Home Depot
Homeline miniature circuit breakers are engineered and designed for fast installation and superior circuit protection. Homeline circuit breakers are designed to plug into Homeline load centers to provide
					www.homedepot.com
