ItsAllDownhill
- Massachusetts
- Electrical Engineer
Frequent lurker here. For those of us in MA, the new plumbing code requires that new substation builds are required to have a gender neutral bathroom "within the facility". I've attached the relevant section here. Needless to say, this is going to cause several problems... in my case, I've got a job where there is city water available, but not city sewer, so per the code I will be required to install a septic and leach field within the substation fence. For the bathroom install, we are looking at installing a stand-alone building along the lines of something you'd find at a municipal sports field. Does anyone here have any experience grounding a septic system / leach field within a substation? I'm more concerned with safety than the land-use or cost components. Both in terms of step and touch and also for the contractors that will have to periodically empty the tank. After nearly 2 decades as a power engineer this is a new one for me. Thank you in advance!
