Question on sharing ground rods: I have an outdoor sub panel, not mounted on the house ( it is mounted on metal structure with the poles in concrete) to power my pool equipment. Taking the " rule out any questions if a separate ground rod is required) I will use two ground rods ( i don't have the equipment to test a single ground rod) for the panel ground.
Here is the question: Can I use/share the ground rod installed below my main service panel to the house as the second ground rod?
Thanks for responses.
