Seven-Delta-FortyOne
Goin’ Down In Flames........
- Humboldt
- EC and GC
This is a fairly typical situation I run into, with my generator/ATS installs.
I'll come off the load side of the MCB and feed the ATS, and then back into the main panel.
For a 200A service, I could use #2. But, if I put them all into one conduit over 24" long, I need to derate to 80%.
310.12(B) says 83% can be used. Then says if no adjustment factors are needed, Table 310.12 can be used.
So my understanding is I can use the "83%" rule, but not Table 310.12.
So I can use an Ampacity of 166 (200 x .83), then apply adjustment from there.
So from Table 310.16, 3/0 has an Ampacity of 225 in the 90C column, multiplied by .80 gives me 180A, which is more than the 166 I have using the 83% rule, so I could combine the feeders in one conduit using 3/0.
Is my interpretation of 310.12 correct in your opinion?
Point of fact I usually use gutter for these situations, which negates all of this, but one I'm bidding now got me thinking about this possible scenario.
