greenspark1
- New England
Hi all, our typical service is a few sets of 4"C so they are run into the service panel via punched openings. They're often in rigid conduit, and use a compression fitting to secure them to the main panel/switchboard. I have read 250.92 (B) several times and can't understand if a 'regular' compression fitting is acceptable or needs additional bonding. (B)(3) seems to mean that they ARE acceptable since we make them up tight.
Does the threaded part of the fitting with a regular locknut provide enough bonding?
I've read the handbook commentary, EC&M article, etc but it seems unclear for this application/example. Thank you!
