Jpflex
Electrician big leagues
- Victorville
- Electrician commercial and residential
At the power production plant I’m currently working at, we have 1500 Vdc solar array input to large inverters with output at 43,500 volts ac supplied to grid.
From the field strings 1,500 Vdc input before the individual inverters and before the dc disconnects, there are what is called choke inductors. Supposedly this is to mitigate the adverse affects of dc pulses but I was wandering if someone here could explain the purpose and theory of these better
Additionally there is a notch inductor and capacitor bank following the 690 volts AC output of the individual inverters. I assume this is to improve power factor and or signal wave or perhaps someone here could explain this better or add to this?
After the 690 volts AC out from the inverters, voltage is stepped up to 43,500 volts AC which must match the grids frequency, voltage and waveform. My third question to this is whether a slight deviation on inverter voltage output to the grid voltage could cause what would be an inrush current or similar to short circuit from the difference of voltage potential? Also how is the frequency and wave form matched to grid?
