4" Transition
EMT connector and threaded coupling I would think.
-Hal
Thats what I have always seen in large sizes.
Thru 1", these are available (691 Crouse Hinds)
The code purists and desk jockeys will have a problem with it, but I'd just use a rigid coupling with the EMT connector screwed into it.
A standard steel set screw coupling will work. No need for a special fitting since the OD of both raceways is the same. Here's one example:
